Hello and good morning,
yesterday I tried again to start ther turbine.
I assembled the glow plug and when I switched on the FADEC there was the message again: COOLING and the temperature was nearly 300°C.
I dissassembled the glow plug and the ambient temperature was displayed.
There is a short circuit between the negativ glow plug wire and the temperature sensor.
It is not the original one, it is a custom made one.
So do you have any suggestions how to solve this problem?
To isolate the sensor is impossible - the only solution is to make the hole in exhaust a little bigger and then hope therewon`t be ashort circuit again
but this is not a acceptable solution....
I am going crazy with this turbine....
Greetings Fabian
