RE: Safe to use DuBro Soft mounts for my Saito 125 ?
Most Saito shaking is not actual vibration unless as mentioned above, the LS needle is too rich. Most of what your seeing is the result of tortional impulses which are the result of a light engine and strong power pulses. A soft mount will exaggerate this. Running a prop like a Graupner 15x8 will help as it has some weight to it.
