RCU Forums - View Single Post - plastic covering
Old 11-20-2002 | 10:11 AM
daveopam's Avatar
daveopam
My Feedback: (9)
Default plastic covering
Jim , you got some great advice from those guys. The only thing I can add is some clean up advice. If you seam a light & dark color together they might bleed a little on the seam. On Monocoat the color is the glue and will run a little and get on your iron. Dont worry about it till your done, then take some Trimsolvent and wipe down the edges. It will take the bleeding right off. Also keep in mind . You will be able to see through the lighter color Monocoat to a certain extent. So make sure the darker color goes on top of your seam if possible.
later daveo
