RCU Forums - View Single Post - Blitzed! Matorro King Tiger
Old 11-13-2009 | 11:59 AM
blitzkrieg65's Avatar
blitzkrieg65
Default RE: Blitzed! Matorro King Tiger
Gotta hit the road today, so I'll be offline! But here are a few pictures that are not olnly teasers but the New 3:1 brass Gearbox from Mato may need some tightening up! Below I show you how the drive axle is loose because not only the last drive gear was loose, but also the coupling that is needed to keep it secure and space correctly to the side brackets!
You will need to alig and re-tighten the allen screws and use a tiny bit of CA (super Glue) to keep them tight! Also for Viper he is getting the Tamyia 380's so this front end needs to be secure!
The Blitz
ID:	1313439   Click image for larger version
ID:	1313440   Click image for larger version
ID:	1313441   Click image for larger version
ID:	1313442   Click image for larger version
ID:	1313443   Click image for larger version
ID:	1313444   Click image for larger version
ID:	1313445   Click image for larger version
