RE: C-ARF Flash Build Thread for All Flash's being built this winter
I am just at the point of installing the pipe I upgraded to a Tamjets pipe to help keep the weight down. Is there any need to install any more heat protection than the aluminum tape and shielding for the servo leads that the instructions recommend. I have ceramic blanket and BVM heat shield on hand, just didn't know if I needed it in the back end of the plane. I am only going to use a the top half of the bypass and am using the NACA inlet cut outs. Power for this one will be a Jet Central Rabbit.
