RCU Forums - View Single Post - Flaps
Thread: Flaps
Old 11-17-2009 | 08:50 PM
TedMo
Default RE: Flaps
As stated by RCKen generally true but have also seen opposite occur. Besides 1/4 inch deflection is almost negligable. Easy to find out just take it up, reduce throttle to idle and give it a try. Nothing that you can't correct will happen. once determined you can then mix some corection in elevator, when flaps are deployed. If desired.
