RCU Forums - View Single Post - jato 1/4 tank cutoff
Old 11-22-2009, 10:25 PM
hyper701
hyper701's Avatar
Default RE: jato 1/4 tank cutoff
check the fuel lines, even a pin hole can cause the engine to run like poo, and cause starting dramers. also check that the tank seal seals properly, if it does not you will loose back pressure causing the engine to stop.
