RCU Forums - View Single Post - Nova ready to maiden!
Old 11-23-2009 | 07:28 AM
billd76's Avatar
billd76
Default RE: Nova ready to maiden!
ORIGINAL: hugger-4641
Looks good, did you get a cowl with it? Here's a couple pics of mine with cowl on.
I know, I know, the fuse is missing a pin stripe on one side. Don't know where it went, but I'm going to re-cover it soon anyway, so I'll just live with it till then.
Yeah I got the cowl with it. Not putting it on until I get the engine dialed in. It's a new engine, well only three tanks of fuel have been rain through it on the ground. I noticed that the pin striping up near the fire wall comes loose alot. I need a rx battery as well. I have a 1500 NiMh 4.8 volt. But with the DX7 I'm thinking it would be safer to run a six volt. But then again, only running four standard and one micro servo, it might be okay. But as Bob said "remember the five P's" so will most likely wait and get a six volt 2000 NiMh. Did you have to add alot of weight to the nose to get in balanced? I balanced my at 4.5 inches. I still have to check the lateral CG. I see that you cut out a large portion on the front of the cowl. Do you feel you really needed to cut that much out? I drilled a large hole in front of the carb. But looking at yours I may need to do a little more. Also looks like you ran pull pull for your elevator as well?? No they can't be, you would have to add another servo.
