Dave, Put her in the water. You will like the way the boat sails. I do hope you built the larger rudder ? I built the ECB in the 70's and converted a friends to RC in the 90's, and the boat sails really well. See a photo of mine at,
www.pondyachts.net Not as nicely detailed as yours, but I couldn't wait to sail her. Did you install ballast ? As i recall it took about 6.5 lbs. +. I used bird shot / epoxy. The hull, less sails, was floated in the bath tub, and the shot was spooned in through the hatches, a little at a time. Easy to adjust the balance that way
