RE: how to repair hbfp?
Mr. I
there should be a parts breakdown/ exploded daigram in your instruction manual which should show you how the head (i believe that is what you're referring to) is connected to the shaft (normally one bolt with locknut)! yes you are going to have to buy a new one! don't ever try and glue something as important and load bearing as the head!!!!
if the head is destroyed the chances are that the feathering shaft is done for as well as the main shaft! you could try to straighten it but for a couple of bucks and knowing you have a true (straight) part.......!?
as an alternative you could try your LHS for help? where did you get it from?
Matty )}}}}@>
