RE: new to nitro
Are you repriming the engine after it gets hot and dies(sometimes it helps)? You could be too rich or too lean on the bottom, or the idle could need raising. It could be an idle mixture problem, but it could also be as you say. The piston and sleeve may be worn and losing compression when the engine gets hot.
Eric
