RE: Steering Servo 1:10 Brushless Advices
the most expensive servo i've seen is $200 when new one of futaba's brushless MG HT HS and any other abreation you can think of on it, stupid speed and TQ as well but to be honest i run a $35 tower Ts 140 in my evader and its VERY fast and the only reason i have a wide turning radius is i keep my diff TIGHT, run badlands which push likea dumptruck on ice and my rear end is dropped and my front is jacked (less wheelies) i've been running this servo since the fall and i've had no issues with it ever, i used to run a futaba s3305 until the motor burned out at the begining of the summer, i've run a tower TS 150 in my savage for two years now with no problems unless you count a stipped gear from a bad landing and a locked servo saver, (if its unlocked you'll be fine in a savage in any other aplication i wouldn't worry)
the specs on the TS 140 .12 speed and 80oz TQ on 6V MG and digital very nice servo
the lug
