ORIGINAL: MinnFlyer
BTW, a trick I learned a few years ago has been very helpful. just remember, ''Thumbs Up''
Stand behind the plane (as you would when you're ready to taxi out). Push the aileron stick with your thumb to one side (even if you normally use two fingers on the stick). Whichever side you push the stick to, that aileron should go UP.
Thumb to the right, right aileron UP
Thumb=UP
Thanks all, Will apply all that has been suggested and advised. Will improvise, adapt and overcome!!
