setup help
Hi guys,
I was wondering if there is any website where I can get details on the Throttle curve and pitch curve setup for X-cell gasser??. The thing is that I am used to 30 size engine, which has one needle to mess with. But I am not used to 3 needles setups, so I would like some details on what to watch for. I have the engine temp. setup on my machine, and also have optical tach. So I would be glad to work with numbers, like the temp the machine should run and optimum RPM for gas.
I would definetly be asking for help around locally but I would like to do my own homework, so any information be helpful. By the way I am planning to add 6.5 lbs of camera load to the heli.
My setup:
X cell gasser w./ Zenoah 23 engine
JR 550T gyro w/ JR 8700 on tail
present 680mm 3D carbon blades (not sure if its better to use bigger)
Thank you.
