ORIGINAL: navy47
Ih Thanks for all the poast. So far I have changed carbs, set the needles and it does pump up gas to the primer, After pulling the starter rope for about 100 times and IT STILL WILL NOT eaven fire. Changed the plug also. I have the fuel line comeing off the bottom of the gas tank going to the bottom of the carb. When I checked the plug it semels like gas but when i ckoked it I did not see any gas come out of the vol stack. Im LOST LOL
Thanks Again for any help.
Tom
are you pulling the motor to get fuel into the primer ? you press the primmer with you finger a few time to prim the carb and get the fuel up the lines, you dont do this with the pull starter
