Okay
So I've it put on my DIY bed setting ...
Front camber was 4 deg one side 5 the other (i've changed that on the spot at the club going from 0 to whatever i've found toaday didn't change a thing in driving so left it lol)
-> I've set it at 2deg each
Toe at the front was 0deg right and 1deg left in toe in
-> I've set the Front toe out by 1deg each side
Rear was 2deg camber on the left 5deg on the right
->I've set it at 3deg camber for both
Left the rear toe in STD as is a shimmer buisness
Might make the chassis feel a bit more healthy I guess but I doubt it will change anything to my "it goes straight on in the curves"
