12x programming
I have been using a 12x for planes, but am programming it for the first time for a heli and have run into two problems.
First, I hooked the gyro gain into Aux 2, selected gyro on the device select, but it would not work. It was assigned to the mix switch. I moved the gain lead to channel 5 and everything worked perfectly. I am clearly missing a trick in setting up the gain on aux 2. Any thoughts?
I am also trying to get the hover pitch trim to work. I can get hover throttle control to work, but not pitch. I understand it won't work with flight modes other than "normal", but that's where I have it set. I have tried assigning the hover pitch to both the knob and the left eyebrow trimmer, but this does nothing. Any thoughts on this one?
Thanks, Keith.
