ORIGINAL: bkdavy
I've never used anything other than Waxed Paper to cover plans, and can't see a reason to use anything else. Its dirt cheap, its readily available at any grocery store, the box is easy to store, and nothing sticks to it. A small piece of masking tape at the corners to hold it in place. There's no reason I can see to want anything to adhere to the plans.
Or are you asking about other materials to use for the monokote decal technique using the Press and Seal?
Brad
Just for the plans, I was just kind of curious if it is feasible and maybe having it stick to the plans and not rub off the adhesive might be a good way to temporarily store the plans if you needed your table for other work. I like to view these threads for new innovations and the monokote with the press and seal is really good tip.
