RE: CLD 26cc Gas Airboat
kinda late but next time to bend the rake mix alcohol and water, using a spray bottle, wet the ply, add weight to the deck as you did BUT do not use so much, use the heat gun to dry the plywood, you will need to repeat the wetting and drying until the ply takes shape. Other wise you are taking a chance of the glue not holding the plywood to shape. I have seen the glue break days after from not using water/alcohol.
