Atlanta 60
Is that a mold in the background for a LA-1 fuse????
That was the plane I wanted to get started with in the early 90's. I ended up starting with a Robbie (Matt) Saphire I. I then moved to the (Geoff Combs) SL-1 with a YS 120 AC after that. The best pattern plane I ever had, IMHO... You would not happen to have templates for cutting a set of foam cores for the LA-1 too, would you????
