RE: MVVS 26 Petrol
If you decide to change the ignition as well, MVVS item # 3312L is a plug and play modern MSR ICU replacement like the one fitted to the latest engines. This ICU ignition is adapted to work with 180 degrees magnets like the Vlach EZM ignition has so it will use the same prop driver.
