RE: Carbon gear servos
JooNorway, that is a very good info regarding Locktite!
On 3D 2m I will be using 15kg on the rudder, just slowly preparing my H9 Extra 260 for maiden.
Actually my question was would it be appropriate to use carbonite gear servos in F3A for ailerons (and rudder?) even on 2x2 plane as Graupner has come out with a servo with carbonite gears of adequate specs: DES 804BB 9.8kg, 0.08s/ 40deg on 6V.
I will definitively try carbonite gears with Wind 110 on the ailerons and horizontal stab: 7.7kg, 0.11s/60deg on 6V. May be I try that 9,8kg Graupner here on the rudder first.
So far I have found carbonite gears to be very smooth.
