Did the O.S. 18TZ have a air cooled or water cooled head? Where do I get a rear exhaust return to center header so it will work with my boat? Thanks....
ORIGINAL: misshydro
Ok I'm chimming in on this......subject because I have one with a CMB.21RS Redhead in it.....your going to have proublems with it..for one they have bad SG.. two alot of mod work you have to do on them to get a.21 to work...three those motor are to much for the hull of that size... I can only drive mine at 1/2-3/4 throtle any faster then that,,the boat become unstable and uncontrollable...I have video's of it running and the boat like to skip/jump like a bunny rabbit...If you want a fast miss bud and be stable?? Put a O.S.18TZ,, this requires no mods,just bolts wright up..hard wear I'm using like adjustable strut and rudder are from the Miss Vegas...if you use the.18 get a mac.21 tune pipe for it too.A-ZRacing did a miss bud with a O.S.18TZ that was GPS at 55mhp!!
had a mac tunepipe 440/3 prop adjustabe strut..
