RE: Redcat Monsoon Thread
which monsoon do you have, the xp or xrt?...this helps some...
as far as what weight oil in the shocks I started out with 50wt in my rxt but havent really ran it much to give any feedback....as far as moving your stock steering servo to the throttle when you have a better steering servo goes, by all means get it switched...you will not only have faster speed and better torque (better brakes) but you also get the durability of metal gears...
if you want to drop around $50 and want some better pep get ya a dynamite pip...these work well on golden lion engines (sh xtm etc..)...which of the 3 depends on what your plans are....if you really want that thing to haul throw a xtm 457 piston/sleeve in that sh.28 and hold on..lol
you can put 2 breather holes in the center of your tires and wheel (if they arent already there)...do em across from each other and they dont need to be very big...maybe 2 or 3 mm
