RCU Forums - View Single Post - Dubro hinge install with pva glue
Old 12-31-2009 | 07:32 AM
ppkk's Avatar
ppkk
Default RE: Dubro hinge install with pva glue
I am sure PVA would work fine, but if you have yellow wood glue (aliphatic resin) around why don't you use that instead. If my understanding is correct, aliphatic resin is similar to PVA but stronger with better resistance to moisture.
