RE: Ventura- new Quique Somenzini design
Hi
I have the Amethyst 2010 version. The wires were tight when I received and after about 60 flight bit loose. It is the foam on the cabanes and wing that compress a little bit. After a days flight of 5 to 6 flights see no movements on the pins.
Be cautious on the weight side if electric. The Oxai listed weight is wrong and further excludes the landing gears and spats and you will have to pull all the stops to get it under 5kg. This includes having to use TP4350 batteries, carbon props and carbon spinner if using Hacker and Jetti Spin set-up.
Regards
Burt
