dear dave as the mail is not going thru i might list the problem here itself and provide u with the video links
Dear Mr. Dave, Thank you for your kind proposition of helping me out. I got the fuel portion sorted by making it tighter with a rubber band (guess air was leaking) anyway now I have an entirely different problem. I hope you would assist me.
By now you would have known I am a total beginner and require assistance in minor things.
After having the gas leak thing fixed I put some fuel in the tank and wanted to start the engine for the first time (please remember this is my first nitro car and I had not even tested it apart from putting fuel).
I inserted new batteries both in the receiver as well as the radio. I switched on the radio first and then the receiver, upon switching on the receiver a small noise was made and the servos moved a bit (tiny bit) when I wanted to check on the throttle there was no movement, similarly for the st trim and the th trim.
I have taken a video where u will see only a tiny movement of the servo on switching on the receiver and after that nothing happens (I hope the video is good enough) even if I try to turn the st or th. Kindly advise as I believe it is not servo issue as it moves a tiny bit when I switch on the receiver. Grateful if u could suggest ways to resolve my problem. Thanks a lot. One more question is whether we can replace servos of RC Helis in the nitro cars or would I have to buy the entire receiver radio combination as I have two spare servo of heli.
the you tube links for the videos are
http://www.youtube.com/watch?v=VJRz_ug5zXE and
http://www.youtube.com/watch?v=NQfn5xTnEOQ
