RCU Forums - View Single Post - GP Extra 300s .60 Build Thread
Old 01-04-2010 | 03:13 AM
twn's Avatar
twn
Default RE: GP Extra 300s .60 Build Thread
ORIGINAL: bgfireman
I am not much of a 3d flyer, so I am not sure about hovering pull out. However she will do a great flat spin!!!
Good luck with the build.
Alan
Try a wound up lomcavek! This plane does the absolute BEST lomcaveks EVER!! If yer no sure then do this:
Turn on high rates, max throw, come in over the runway from your left about 10 feet over the runway, be sure to be level and fairly fast flying about 1/2-2/3 throttle. About 40% down the runway go full throttle (keep her full throttle all the way through this) pull to a 45, immediately roll to the right into a knife-edge, center yer right stick, holding the 45 degree knife-edge for about a half second, then roll hard to the right, wind her up about 2 rotations and then throw both left and right sticks to the right and top and hold both sticks 4 rotations. She will tumble almost end over end! If you have enough power and wind it up enough she will go end over end. It's gotta be the easiest maneuver ever but this plane oh man, u will see!! VERY impressive!
You don’t have to do the knife edge, but that is how the real maneuver is entered, looks better. You can just go into the 45 then wind her up if yer not comfortable with knife edge that low and that fast. Be warned this maneuver is very hard on the airframe especially when entered fast…
