RCU Forums - View Single Post - mamba is good...no?
Old 01-05-2010, 07:47 PM
  #32
BigTb17
Default RE: mamba is good...no?
ORIGINAL: vpower
ok are you all listening too me?javascript:void(AddText('[:@]','_image/s6.gif'))
i said i wont use it offroad untill i prove im the fastest at a drag race here in miami Florida,s tropical park ill be running a rhino 1550 mah 3s li-po once i prove im the fastest i will buy a 2s li-po and gear it down for off road (yes i will put a fan on the thing)[&:]
That Li-po is going to be way overstressed. It may simply drop voltage really bad and not provide much power. However, it may also be damaged or even overheat. Even at 25C that battery won't be good for over 40 amps. That 9000KV motor could draw twice that amperage and probably even more on 3S.
Like I said, people's advice on here can't stop you from doing what you want. However, you asked for people's opinions and they gave them.
Either way, post your results.
