RCU Forums - View Single Post - Ether or not Ether ?
Old 07-10-2003 | 11:45 PM
AMB
Default Ether or not Ether ?
it may start run poorly impossible to adjust and stop as soon
as you disconnect the glo power adding ether will not help
the compression on glo engines not high enough if you want
a diesel get a diesel head (if one is made for your engine)
then your set to go best source davis diesel
