Originally posted by sandal
CurtD;
so if an altimeter is available, you could set it at 29.91 and sort of read how much power your model engine is going to make...?
That would only give you "pressure" altitude (set the altimeter at 29.92 and read the apparent or pressure altitude). There's a calculator available that allows one to enter air temperature, ASL altitude, humidity, and current air pressure to get calculated density altitude.
There are also electronic altimeters that can automatically calculate and display density altitude. Impress your friends and add one of those to your flight box!!
Here's the link:
http://www.aircraftspruce.com/catalo...ges/taskem.php
