RCU Forums - View Single Post - PICA Cessna 182 build
Old 01-10-2010, 02:12 PM
duradad
My Feedback: (40)
Default RE: PICA Cessna 182 build
Hi,
Have you found any help with your Pica 182?
I just acquired a partially completed model that , I suspect, is a Cessna 182 by Pica. It may be a scratch build because some parts have numbers that look to be hand written and the holes through the fuse formers look like they were not die cut. (does this sound like your kit?). However, it came witha fiberglass and a plastic cowl, plus a molded front window, and it is about 72 inches in Wingspan. So, it may be a Pica kit.
The wing, flaps, ailerons and fuse are built, but not fully planked. The tail surfaces are missing
I'm hoping to find drawings so that I can build the tail feathers and finish. My biggest problem will likely be finding a plastic rear window for it.
I'd appreciate knowing what you have learned.
Bob
