RE: saito 72 4c open or closed
You can also use a thin piece of wire bent so you can get it inside the carb, I use dental wire and it comes in different thickness so I can even set my low end without seeing it. Just fit it in aND FEEL WHAT WAY IS OPEN AND CLOSED.
