RCU Forums - View Single Post - Brian Taylor OS2U Kingfisher Build
Old 01-13-2010, 10:56 PM
chistech
Default RE: Brian Taylor OS2U Kingfisher Build
Got my buddie's plans copied and scaled down today. Had to change his plans down from 1 3/4" =1' to the BT which are 1 5/8" = 1'. The copying company computed a difference of 92.8 percent. Copied the first sheet and measured the wing. It was 58" just like the BT so the percentage was correct. The plans are Charlie Smith plans from AZ. My bud has had them since 1980. The plans show all the float bulkheads and mountings. I think this would have helped Scale Dail with his. If you need any copies of the tip floats let me know. The plans even have a design for the rear machine gun. Will have to put the gun in for sure.
ID:	1355702   Click image for larger version
ID:	1355703   Click image for larger version
ID:	1355704   Click image for larger version
ID:	1355705   Click image for larger version
ID:	1355706   Click image for larger version
