RE: Need help with gyros
You would have to position the gyro on its side so it measured up and down instead of side to side, it would also have to be mounted in the turret. You would then need one in the tank to keep the turret in the correct rotation. You may have to use one that has what is called tail lock as it will when set will try to keep the chopper in the same direction. Good luck.
Cheers
