RCU Forums - View Single Post - Wow, it worked!
Old 01-19-2010 | 12:57 AM
The Ghost's Avatar
The Ghost
Default RE: Wow, it worked!
Good work, you will get better the more you make, the more time spent with the plug(smothing it) the better the finished product. You could of made the cowl out of a foam block and then do the same thing with epoxy finishing resin and when set use a little petrol to desolve the foam and you have the cowl. I use this for a lot of builds.
Cheers
