Where are you hiding your switches?
ww2birds,
Thanks, makes sense. I think I'll be in the same scenario as you were in your "second scenario" with my kill switch. I've got a similar gap between my firewall perimiter and the back edge of my radial cowl. I might just set up that switch there.
Still not sure about the air system valves and radio switch. I might even be able to "hide" the radio switch in the gunner's radio compartment when I build the cockpit up. Kinda ironic... puttin' the "radio switch" in the scale gunner's "radio compartment"?
Foxx,
You tricky devil... so that's why they call you "foxx"?
What about your gas filler/fuel dot... same place? Seems like you might risk getting gas in/on your switches if so??
Neo
