RCU Forums - View Single Post - Quick Disconnects/Push to Connect
Old 01-27-2010, 06:13 PM
Thud_Driver
Thud_Driver's Avatar
Default RE: Quick Disconnects/Push to Connect
If I recall correctly, B. Wilcox told me that a Jetcat pump (Hausl pump) is considered "good" if it puts out 80 psi at 3.7 volts (power supply volts, not ECU volts).
George Manning checked a bunch of older pumps, a dozen or so, we had between us and the results ran anywhere from the low 70's to 90 psi.
