ORIGINAL: Shake n Bake
ok, could i get 2 3s 11.1v 30c 3200mah packs and use them together?
Two 3S packs, yes with a series connector. 3200mah 30C no. That's only 96 amps peak output. You want about twice that for safety's sake. To find peak output: Convert to Amp hours (move decimal 3 places to left), then multiply by the C rate.
3200mah is 3.2Ah X 30C = 96amps peak output.
