RE: Springer Build
Hey Toes...no...what I actually got was the "construction workboat" that is 16 X6 with a 2 3/4 inch depth. I am using a 545 mtr from Vac-U-Tug, a 1/1/2 3 blade brass prop, 50amp waterproof esc, and two 7.2 3800 mha batts in parralell for ballast. It appears on initial hot tub test the water line will be close to being right. If not since I am also a hunter, I use the flat strip pieces of lead that are really duck decoy weights for ballast. This is going tobe my RESCUE boat....that is along with a couple of others. You know how this hobby is...habit forming!! Progress pix attached....Dave
