RCU Forums - View Single Post - My Laser Cut Air Boat PROTOTYPE
Old 02-09-2010, 09:56 AM
  #70
claserdesigns
My Feedback: (14)
claserdesigns's Avatar
Default RE: My Laser Cut Air Boat PROTOTYPE
ORIGINAL: tanasit
In stead of flat bottom, how about the tunnel hull that should improve the straight line performance as well as the speed.
As for the motor mount, from the pictures I think perhaps if I enlarge the mounting holes on the vertical supports (either the top or the bottom pair) into the arc only about 1/8", that should do it.
I designed the Anarchy so it will slide "drift" on corners,by adding a tunnel hull design will eliminate the fun ofdrifting on the waterbut I'm experimenting with vacuum plastic molding and this will give more design options on my future products. I will look into doing an airboat design with a tunnel hull.
