ORIGINAL: rcairflr
ORIGINAL: Hammbone
Servos with limited current flow still work, they just have less strength (torque).
Jim
The servos will never be even close to max'd out on the ailerons unless you are hanging a brick from them and until you hit the limit of the weakest point in your system, there will be no difference in operation.
I agree with part of this statement. "Until you hit the limit of the weakest point in your system, there will be no difference in operation."
I believe that the limit is reached much sooner than you do, though.
These new high torque digital servos use a lot of amps, and I think when you are trying to power 2 of these servos through one standard connector, the servos will not get the current they need.
Even if you are able to force excess amps through the one standard connector, you are then going to get a voltage drop, which will also weaken the servo and cause less torque.
Jim
