RE: Hitech/futaba wierd failure
Don,
I'm unaware of other problems with OEM compatibility issues with regard to Hitec synthesized TX module less the occasional RX that simply will not work. I suspect it has do with varying degree of component specifications of the specific RX in hand, i.e. + or - tolerances to name one.
PPM - PCM or NEG-POS shift requirements or considerations are a moot consideration. If the TX and RX in play are capable of meeting the needs of same, any TX module will work as this stuff is all defined ahead of the module and at the RX.
That said PCM is proprietary you must use a like OEM brand TX and RX to go there. Any compatible TX module on the appropriate band will work in my experience.
With any combination a rigorous and thorough range check is paramount to continued operation of the model….
