RCU Forums - View Single Post - Do the flight characteristics stay the same..
Old 02-23-2010 | 11:30 AM
Pete737's Avatar
Pete737
Default Do the flight characteristics stay the same..
Given a particular CG, Will a jet perform the same (controllable) regardless of it's armament? If your recommended CG is say, 150mm, Is it the same if you are going to carry a full ordnance? Forgive me if this is a dumb question but I was considering the possibility that wing (and fuse) mounted devices may distribute lift a bit differently, Affecting the recommended CG location.
Thanks! Pete
