ORIGINAL: scotty052048
1. The website gives a range of 3000 ft. The included book says 1000 ft. I didn't even unpack
the plane until someone convinced me 1000 ft was good enough. The site still says 3000.
The web master would have to be notified to change the ad, but that person doesn't check in here...
Got bored and decided to charge the battery and taxi it around the basement. Everything went well
for about 30 seconds. Then the right elevator servo started jerking the locked up.
I had the same problem with one of mine, ( BTW: My paint scheme looks GREAT ). I ended up replacing the servo with on of the TowerPro 9G servos and have not had a problem since.
Now I have a pretty piece of junk that I don't have a clue how to even fix.
You can either change the servo out ( easiest fix ) or PM John here with the above.
Be sure to include your order number.
However since the Art-Tech's are no longer being sold, if you do PM him, ask for a substitute if he does not have a way of fixing what you have.
I'd just replace the servo. Much easier...
