RE: Brian Taylor OS2U Kingfisher Build
worked on sheeting the center section top today. I had to finish up the shear webbing on the second mid section spar over the wing mounting bolt area then I cut the sheeting, taped it together, carpenter glue, and then sheeted the wing. I use CA thick on the first edge to hold the sheeting then I carpenter glue all the ribs then thick CA the other edge at the main spar. Finish off the wing with the one piece for the leading edge. After all was set for a while, I unpinned the wing and up it came. I did the "static pinned" assembly to get a look at her. You can see in the pictures she's starting to come together now. Will start on the underside of the wing with the servo mounts and other things so I can close the wing up.
