RCU Forums - View Single Post - A-10 brushed
Thread: A-10 brushed
Old 03-02-2010 | 02:13 PM
opjose's Avatar
opjose
Default RE: A-10 brushed
Replacing the EDF motors is doable but not easy.
In your shoes I'd get a new brushed ESC ( they are cheap ) of slightly higher capacity than the one which is included, that supports LiPo packs. Many do either out of the box or via a jumper or switch.
Then use a 1200mAh or so 3S 11.1v Lipo pack ( you'll need a charger for LiPo too ).
This will produce MUCH more power from the motors.
Note the brushes will wear faster, but they will probably outlast the plane never-the-less.
Just avoid flying the plane at full throttle after the conversion. Give it enough to get up and then try to keep the throttle below 80-90% after takeoff with this combo.
You'll be driving the motors at higher voltage, but they will tolerate it.
They'll tolerate 11v+ for short bursts. You just don't want the windings to get hot and burn out.
