RE: Pitch vs Vertical Perfomance & Downline Braking.
One thing to check is whether your low speed needle is too lean. A lean low end needle will cause the engine to stay pretty well wound up on a downline, so you may want to try richening it a bit at a time to see how far you can go before you don't like the rest of the low to mid-range response (especially when throttling back up).
