You will be VERY IMPRESSED with it !. Trying to figure out a spring shock absorbing tail wheel set-up. What came with it is pretty stiff. Use better quality pushrod parts and consider painting the inside of the cabin. The rest is just great !!. About 15 pounds weight, so a Saito 1.50 will work. Wren turbine would be nice [ if you have that kind of money]
Glad they had some left in stock, they are going to go quickly. Mine came today at 2
m MST, will start first thing in the morning. MM
