RCU Forums - View Single Post - Three- line setup
Old 03-08-2010 | 08:38 PM
rgm762
Default RE: Three- line setup
this is a little better picture of the filler, the line from your tank hooks up to one nipple, the other nipple goes to the carb, to fill just unhook the small piece of tube in the middle and fill, to drain, hook up to the same small piece and drain, you can even use it to do a pinch test plus you only have to use two lines
http://www.airborne-models.com/html/...asp?AGroupID=4
